Activity Forums Apple Final Cut Pro Legacy Problem playback with HD footage
  • Problem playback with HD footage
    Posted by Camille Thoman on May 8, 2006 at 7:54 pm
    Hi there,
    I am editing HD footage shot on a Sony HDV Z1. I have a G5 (single–1.8) and FCP 5. It is dropping frames like crazy. I can play through it by changing my settings and playing over dropped frames. However, I am editing a music video, and my cuts need to be frame accurate. But the playback isnt rame accurate. I think Ive made a cut on the beat, and it turns out–I havent.
    How do I best deal with the footage? And if there is no quick answer, is there a way fro me at least, once most of the editing is done, to do something so I can at least watch the same way twice, and output it?
    Camille
    Mark Maness replied 20 years, 3 months ago 2 Members · 1 Reply
  • Mark Maness
    May 8, 2006 at 8:46 pm
    Are you editing in the HDV settings? If so, that is your problem. In order to edit in the HDV codec, you’ll need a capture card that supports HDV playback. Secondly, I would have to say that you computer is a little on the slow side for HDV. HDV in its native codec really needs a super computer to run. I would have to say that most of us using HDV capture it using our capture cards into another codec.
    Sony even mentions that HDV is really a transport stream, not a playback stream. That’s why it doesn’t edit very well at all. It has to convert the video from data to video and back to data in real time – that doesn’t work very well. Ingesting it as DVCPRO HD or uncompressed 1080i works wonderfully with HDV if you have a converter box like the AJA HD10A or the Mirdana HDV-Bridge.
    _______________________________
    Wayne Carey
    Schazam Productions
