Problem opening Vegas Pro 13 in Windows 10
Greetings,
Like numerous others I too seemed to have run into the issue of Vegas not wanting to open in Windows 10. Unlike others it crashes automatically when trying to run it, not even getting to load dll’s/create windows/etc. I get the following error from the problem report, which only points to the program’s exe instead of a specific loading issue.
Problem Description
Application Name: Vegas Pro
Application Version: Version 13.0 (Build 453) 64-bit
Problem: Unmanaged Exception (0xc0000005)
Fault Module: C:\Program Files\Sony\Vegas Pro 13.0\vegas130.exe
Fault Address: 0x00007FF63A87A710
Fault Offset: 0x000000000081A710Fault Process Details
Process Path: C:\Program Files\Sony\Vegas Pro 13.0\vegas130.exe
Process Version: Version 13.0 (Build 453) 64-bit
Process Description: Vegas Pro
Process Image Date: 2015-06-05 (Fri Jun 05) 21:53:04The same also occurs with my old copy of Vegas Pro 12. Browsing here and elsewhere for a few days I tried numerous things such as clearing settings while launching it or disabling my NVIDIA card/integrated graphics to gain access as it seemed like a common temporary solution, but nothing worked.
Both 12 and 13 launch in minimal safe mode, so I attempted the solution presented here: ( https://www.tomshardware.com/forum/id-2799221/windows-stopping-sony-vegas-opening.html ). I was actually able to get 12 running normally, but on restarting to do the same for 13, 12 once more fell back into the error and I’m back to square one for Vegas overall as I can’t replicate the success of that process.
I’m sure there is probably a bit more info I could provide for the case, so if anyone can lend me a hand then please let me know what I need. Thanks for any assistance.
