Activity Forums Apple Final Cut Pro Legacy Problem opening FCP 4.5
  • Problem opening FCP 4.5
    Posted by Tucker Lucas on August 13, 2009 at 5:49 pm
    Hi there,
    I’m running FCP 4.5 on a Powermac G5 with OS X 10.3.7.
    I’ve been using it successfully for about a year until today. Whenever I open FCP from my dock, it gives me the opening title splash screen, but then sticks on that and doesn’t do anything else. The dock says the Application isn’t responding so I have to force quit.
    I’ve restarted multiple times, I’ve reset the P-RAM, I’ve done disk utility and repaired permissions on the hard drive the software sits on, and still nothing is fixed. Any ideas?
    -Tucker
    Tucker Lucas replied 17 years, 1 month ago 2 Members · 2 Replies
  • John Fishback
    August 13, 2009 at 6:17 pm
    Have you trashed FCP prefs? If not, try that.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 2 (FCP 6.0.5, Comp 3.0.5, DVDSP 4.2.1, Color 1.0.3)
    Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
  • Tucker Lucas
    August 13, 2009 at 7:08 pm
    That ended up fixing it. Thanks man!
