Problem on sony vegas appearance
Posted by Bahrian Umamah on July 23, 2014 at 5:56 amneed help on sony vegas,,,
my editting window is only half and some of the menu is not showed,,,
i try to expand it but i only got the same result,,,
is there any way to solve this ??Bahrian Umamah replied 12 years, 1 month ago 5 Members · 11 Replies -
Graham Bernard
July 23, 2014 at 7:49 amWhat Version and BUILD number of VP have you installed?
G
Cameras: Canon XF300 + PowerShot SX50HS Bridge -
Bahrian Umamah
July 23, 2014 at 1:49 pmthank you for your respond…
the version of my sony vegas is 10.0c (build 469) -
Graham Bernard
July 23, 2014 at 3:01 pmVP10 has been my least liked version.
VP 10 topped-out at E. You may wish to read, download and install this last incarnation of that particular spawn.
Here’s the link:
https://dspcdn.sonycreativesoftware.com/releasenotes/vegaspro100e_readme_enu.htm
VP10?
G
Bob Moyer
July 23, 2014 at 6:01 pmI just opened the same color corrector effect in both VegasPro 10e 32 and 64 bit/Windows7 and the plugin opened correctly. Perhaps your install of 10c is corrupt, but I would definitely download 10e and try it.
Bob
Norman Black
July 23, 2014 at 8:57 pmIt looks like you changed the default font size in Windows away from something other than the 100% default. A lot of apps cannot deal with this change.
John Rofrano
July 25, 2014 at 1:01 am[Norman Black] “It looks like you changed the default font size in Windows away from something other than the 100% default. A lot of apps cannot deal with this change.”
That’s exactly what it looks like. Window gets really messed up when you change your default font DPI. Don’t do it. Change it back to 100% and everything should be fine again.
~jr
http://www.johnrofrano.com
http://www.vasst.com -
Bahrian Umamah
July 30, 2014 at 4:52 pm -
John Rofrano
July 31, 2014 at 2:15 am[Bahrian Umamah] “i think with installing a new version would solve the problem, but when i check on some effect, for example “film effect” i still found the problem,,,”
That’s because the problem is that your windows font DPI is not set to 100%.You need to set it back to 100%.
~jr
Bahrian Umamah
August 3, 2014 at 2:39 am -
John Rofrano
August 3, 2014 at 5:13 pm[Bahrian Umamah] “here is the display of my font size”
Why is 9 point Segoe UI at 96 pixels per inch crossed out on your Windows Custom DPI Settings? Mine doesn’t look like that. I’m guessing that this has something to do with your problem. Also I have Smaller 100%, Medium 125%, and Larger 150% but you don’t have the 150% option. Something is not right with your Windows setup. I would try and figure out why that text is crossed out. If it means it’s not available, that’s the problem because you need to have 96 DPI for things to look correct.
~jr
