Activity › Forums › Adobe InDesign › problem on positioning (open type feature)
Posted by Symeon Monk on January 10, 2019 at 6:44 amI have made a pair adjustment on my opentype font in MsVOLT. The first character of the pair is raised. Everything is working fine, unless this pair is at the beginning of a line. In this case, not the first character is raised, but the second and ALL the next untill the end of the line come down!
Symeon Monk replied 6 years, 10 months ago 3 Members · 10 Replies -
Kalleheikki Kannisto
January 11, 2019 at 4:25 pmMsVOLT… never heard of it before. The first two letters are already suspect. I’ve edited font in a couple of different font design software (Fontographer, FontLab), the only problem that I’ve encountered has been conflicting font ID numbers.
Did you try if it works in other software than InDesign or did this program mess the font up for every program? Such as MsWORD, or Illustrator, etc.
I (somewhat preconceivedly) expect MsVOLT to be the issue, not InDesign.
Senior Graphic Designer -
Symeon Monk
January 12, 2019 at 6:46 amPlease, try the attached font. It is a small part of a byzantine music font.
Try the 2 characters | and s. See in the attached indd file (and the pdf) the second line. Instead of raising the 1st, the 2nd character is going down! In the 3rd line, where the | is not at the beginning, there is no problem.
13024_ccschourmapostolostest.ttf.zip
13023_testbug.pdf.zip
13022_testbug.indd.zip -
January 12, 2019 at 8:54 amSwitching from metrics to optical kerning fixes the issue, although I don’t know if the result looks like you want it to, in terms of where the characters are located in relation to each other.
Symeon Monk
January 12, 2019 at 9:00 amOh, I need the Metrics option. The entire font has hundred of such kerning settings!
January 13, 2019 at 9:04 amOther than doing the fix in another font editing software, which would be a more permanent solution and which I would suggest, there is a temporary “easy fix”, which is to use the original font but make a character format with suitable baseline offset and/or kerning values for that one letter and then use a search and replace to assign the character format to that letter in one go. Obviously you would have to do remember to do this every time, so it is not ideal.
Looks like Fontographer and Fontlab are both owner by Fontlab these days. Those are the two best font editing software that I know of. Kinda pricey though.
Symeon Monk
January 13, 2019 at 10:47 amThe Fontlab software is indeed unique for constructing a font. But for adjusting the open type features, VOLT is light years ahead! It is just irreplaceable.
So, there is no genuine solution for this case? Is it a bug in fact?
January 13, 2019 at 4:36 pmThis is going to be guessing, since I don’t know what MsVOLT does, but one thing that does seem unusual is that the font is a TTF font while you’re using OTF features. Have you tried saving the font as OTF? Maybe that confuses InDesign?
MsWord doesn’t recognize this as an opentype font and I can’t get your modifications to even show up there regardless of it being a Microsoft piece of software. That’s kinda fishy, isn’t it?
Symeon Monk
October 24, 2019 at 6:21 amI have just tried my font on InDesign CC 2018. There has been a new problem. InDesign does not recognise the variable anchors I have adjusted for positioning marks onto ligatures. All the marks are put on the first component of the ligature. Can anybody help me?
Symeon Monk
October 29, 2019 at 6:52 amI’m so sorry! I had installed an old version of the font… It’s Ok!
