Activity › Forums › Adobe Premiere Pro › problem of rendering with stills and premiere pro 2.0
  • problem of rendering with stills and premiere pro 2.0
    Posted by Billyj on March 6, 2006 at 7:06 pm
    I’m working on a small edit with only high res stills (4000×4000 pix), moves, fades and titles. When rendering only 3 minutes, I noticed an amazing calculating time with ppro 2.0 : over 1 hour. With ppro 1.5, it used to take 10/15 minutes for the same kind of edit. So I made some tests. I put a 4000×4000 pix still on the timeline for a duration of 5 sec. Then I made some fades in/out and added a title over.
    I noticed everything is fine in the rendering till I change the scale of the still:
    as long as the scale of the image remains over 50%, the rendering time is ok (around 5 sec). Since I go under or equal to 50 % the calculating time becomes crazy (more than 4 minutes). What’s the problem with ppro 2.0 ? I hoped that the stills problems of ppro 1.5 (green screen, freeze, etc.) were fixed. It seems it is not.
    Could someone else confirm the result of the test with high res still ? Thanks.
    Aanarav Sareen replied 20 years, 6 months ago 3 Members · 4 Replies
  • Aanarav Sareen
    March 6, 2006 at 8:06 pm
    [billyj] “I hoped that the stills problems of ppro 1.5 (green screen, freeze, etc.) were fixed. It seems it is not.”
    Incorrect. The green image bug was fixed in this release.
    [billyj] “What’s the problem with ppro 2.0 ?”
    Premiere Pro 2.0 takes an extremely long time to render stills. I can confirm it and so can many others. You are not the only one.
  • Billyj
    March 7, 2006 at 8:12 am
    I know green screen has been fixed (it seems so), but it is replaced by this amazing rendering time. Who knows, maybe rendering time will then be “fixed” by some red screens… Why is it so hard to solve and to check this kind of bugs before releasing the software ? Marketing is easier than programming.
  • Creig Bryan
    March 7, 2006 at 7:17 pm
    “Premiere Pro 2.0 takes an extremely long time to render stills. I can confirm it and so can many others. You are not the only one.”
    Does GPU accelleration have any effect on this?
    Keep Smiling
  • Aanarav Sareen
    March 8, 2006 at 3:27 pm
    [creig bryan] “Does GPU accelleration have any effect on this?”
    Unfortunately, no.
