Activity › Forums › Adobe After Effects › Problem Morphing Chris Zwar tutorial
  • Problem Morphing Chris Zwar tutorial
    Posted by Alberto Bernad on March 23, 2010 at 5:52 pm
    Hi!
    Chris Zwar Morphing Tutorial:
    I made step by step but there was a problem. The mask 2 of layer below doesn’t fit with the mask 1 (mask of fist layer). Do you know what i mean? This is a big problem because when you apply a disolve, i can see both layers for a few frames. If you need to understand better what im saying, please let me know and i cant send you a few screenshots.
    Thank you very much!
    Cheers!
    Alberto Bernad replied 16 years, 6 months ago 2 Members · 4 Replies
  • Alberto Bernad
    March 23, 2010 at 7:26 pm
    UAU!
    Thank you for the question, but both layer has the same pixel aspect ratio. The footage are: two shots DVCPRO HD 1080p25 1440×1080 and the comp size is: HDTV 1080 25. I don’t know if it is wlel done, because with other size comp, After don’t keep my footage pixel aspect ratio.Am i doing something wrong from the beginning.
    Thank’s Dave
    I send you my greetings from Spain!
  • Alberto Bernad
    March 23, 2010 at 8:10 pm
    I know, i know, but i dont understand why this step is so important to make the morphing. The masks are the same in any comp size, no?.
    To be more specific, are two close up shots and my mask only is around the faces. Is like in the reshape effect don’t care about some correspondence points. Why in the tutorial man’s face fits perfectly on sheep’s mask?
  • Joe Moya
    March 23, 2010 at 10:16 pm
    sounds like you need to resize either the mask to fit the face or resize the face to fit the mask
  • Alberto Bernad
    March 24, 2010 at 9:11 am
    OK. Thanks Joe. I keep trying it. In fact the problem is that both faces doesn’t have de same size inside thes shot, thats why when i use the dissolve the second face appears before the morphing. Maybe i have to adjust more the masks.
    ….work in progress!!!
