Activity › Forums › Apple Final Cut Pro Legacy › Problem mixing dvcpro rendered out of nuke..
  • Problem mixing dvcpro rendered out of nuke..
    Posted by Joel Arvidsson on September 10, 2010 at 8:41 pm
    What settings do you have when exporting dvcproHD out from nuke. I export for use in a final cut project with dvcprohd timeline.
    If I in final cut, mix a dvcpro rendered clip from nuke, with original clips from camera (hvx200 dvcpro hd 1440×1080) it looks good in timeline. But if I output from fcp to a dvcpro hd file. Then that clip gets messed up aspect and needs to be rerendered if opened up in fcp??
    In nuke I do this. Import orginal dvcprohd 1440×1080, change colorspace to srgb and choose an write node and then export it as dvc prohd 1080p25. I dont check the premult, raw or use format aspect.
    As long I only use clips that has been rendered out of nuke with this settings everything is good when render out of fcp. But as soon I mix in other clips I get the problem. Also I get the same problem if I only work with clips from nuke and ad an colorcorect filter in fcp.
    Is there any angels here?
    joelarvidsson@gmail.com
    Michael Sacci replied 16 years ago 2 Members · 1 Reply
  • Michael Sacci
    September 10, 2010 at 9:17 pm
    [Joel Arvidsson] “1440×1080”
    That is NOT the pixel count of DVCProHD, it is 1280×1080 (960×720 is the other HD) The 1440 if HDV normally.
