Activity › Forums › Apple Final Cut Pro Legacy › Problem mixing dvcpro from nuke with other dvcpro
  • Problem mixing dvcpro from nuke with other dvcpro
    Posted by Joel Arvidsson on August 27, 2010 at 9:57 am
    What settings do you have when exporting dvcproHD out from nuke. I export for use in a final cut project with dvcprohd timeline.
    If I in final cut, mix a dvcpro rendered clip from nuke, with original clips from camera (hvx200 dvcpro hd 1440×1080) it looks good in timeline. But if I output from fcp to a dvcpro hd file. Then that clip gets messed up aspect and needs to be rerendered if opened up in fcp??
    In nuke I do this. Import orginal dvcprohd 1440×1080, change colorspace to srgb and choose an write node and then export it as dvc prohd 1080p25. I dont check the premult, raw or use format aspect.
    As long I only use clips that has been rendered out of nuke with this settings everything is good when render out of fcp. But as soon I mix in other clips I get the problem. Also I get the same problem if I only work with clips from nuke and ad an colorcorect filter in fcp.
    Is there any angels here?
    joelarvidsson@gmail.com
    Jeremy Garchow replied 16 years, 1 month ago 2 Members · 1 Reply
  • Jeremy Garchow
    August 27, 2010 at 12:29 pm
    Not familiar enough with Nuke, but when I used to do a lot more work in Dvcprohd and use after effects, I’d simply work at the square aspect ratio and render that way as well. Fcp was no worse for wear.
