Activity Forums Adobe Premiere Pro problem mixing audio on the fly
  • problem mixing audio on the fly
    Posted by Brett Nelson on April 7, 2006 at 3:35 pm
    I’ve encountered a strange problem. I am trying to mix on the fly. It works well in one project and not at all in another. When I use the audio mixer, I’ve tried changing the settings to Off, Latch, Touch and Write. When I mix, I hear the level change, but when I go back, nothing is different. Are one of my audio conforms corrupted? I tried making a duplicate of the sequence, but that doesn’t do it.
    I’m running PPro 2. Thanks!
    Brett
    Xavier De champs replied 19 years, 11 months ago 3 Members · 2 Replies
  • Jazzfan222
    May 2, 2006 at 3:16 pm
    I too am having “mixing on the fly” problems. This is a tough one. Keyframes seem to just build up to where there are dozens of them on any clip I have tried to mix. Sometimes things are remembered but only for a while. Some clips are far worse then others – never accepting my directions at all.
    Any solutions?
  • Xavier De champs
    May 21, 2006 at 1:52 am
    I was annoyed by a similar problem, until I figured out, that if you have an IN and OUT point set, the mixing only gets remembered between the two points. So….remove the IN/OUT points. May it helps.
