Activity Forums Apple Final Cut Pro Legacy PROBLEM: mixed formats (XD CAM and DV PAL) in sequence
  • PROBLEM: mixed formats (XD CAM and DV PAL) in sequence
    Posted by Annu Lilja on May 24, 2008 at 8:49 pm
    I’m working mainly with material frm HD CAM, and therefore my sequence settings are
    Frame size: 1920 x 1080
    Aspect Ratio: HDTV 1080i (16:9)
    Pixel Aspect Ratio: Square
    Field Dominance: None
    Compressor:XD CAM EX 1080p25 (35Mb/s VBR)
    I also have some DV material. At first I did not have a problem mixing the two formats in the same sequence. At some point though, I have copied material to another sequence, and the sequence settings for that sequence are
    Frame size: 720 x 576
    Aspect Ratio: CCIR 601/DV PAL (5:4)
    Pixel Aspect Ratio: PAL-CCIR 601 (720×576)
    Field Dominance: Lower (Even)
    Compressor:DV-PAL
    In THIS sequence, the DV material appears to be zoomed in. If I change the setting to match the FIRST settings, the XDCAM material appears in a little box in the middle of the monitor, and the DV material appears as a normal size. Copy pasting the material to a sequence with the first settings does not help the situation either.
    What can I do to see both the DV material and the XD CAM material as a normal size?
    Will I havve trouble exporting this sequence (burning a DVD of it) with the two different formats?
    I am in a rush with this problem, so I really appreciate any hints I can get.
    Thanks for your help!!!
    Annu
    Rafael Amador replied 18 years, 3 months ago 2 Members · 1 Reply
  • Rafael Amador
    May 25, 2008 at 2:16 am
    Hi Annou,
    Go to; Users Preferences> Editing.
    Down in the right corner check “Always scale clips to sequence size”.
    Mac OX 10.5.2-FC 6.02-QT 7.4.1
    G5 2x2Gh 4GbRAM-BlackMagic Extreme
    PMBP 17″Core2Duo 4GbRAM-AJA ioHD
    JVC DTV-17″
    SONY EX-1 . SONY PD170
    ..and always a big mess on top of the table.
