Activity Forums Apple Final Cut Pro Legacy PROBLEM: mixed formats (XD CAM and DV PAL) in sequence
  • PROBLEM: mixed formats (XD CAM and DV PAL) in sequence
    Posted by Annu Lilja on May 24, 2008 at 8:50 pm
    I’m working mainly with material frm HD CAM, and therefore my sequence settings are
    Frame size: 1920 x 1080
    Aspect Ratio: HDTV 1080i (16:9)
    Pixel Aspect Ratio: Square
    Field Dominance: None
    Compressor:XD CAM EX 1080p25 (35Mb/s VBR)
    I also have some DV material. At first I did not have a problem mixing the two formats in the same sequence. At some point though, I have copied material to another sequence, and the sequence settings for that sequence are
    Frame size: 720 x 576
    Aspect Ratio: CCIR 601/DV PAL (5:4)
    Pixel Aspect Ratio: PAL-CCIR 601 (720×576)
    Field Dominance: Lower (Even)
    Compressor:DV-PAL
    In THIS sequence, the DV material appears to be zoomed in. If I change the setting to match the FIRST settings, the XDCAM material appears in a little box in the middle of the monitor, and the DV material appears as a normal size. Copy pasting the material to a sequence with the first settings does not help the situation either.
    What can I do to see both the DV material and the XD CAM material as a normal size?
    Will I havve trouble exporting this sequence (burning a DVD of it) with the two different formats?
    I am in a rush with this problem, so I really appreciate any hints I can get.
    Thanks for your help!!!
    Annu
    Annu Lilja replied 18 years, 3 months ago 1 Member · 0 Replies
  • 0 Replies
