Activity Forums Apple Final Cut Pro Legacy Problem matching capture & timeline settings for instructional videos
  • Problem matching capture & timeline settings for instructional videos
    Posted by Lowell on July 28, 2005 at 8:19 pm
    Hello,
    I’m using screen-recording software (Snapz Pro) to create an instructional video and then FCP to edit the captured .mov file. I have 2 questions. Any help or suggestions are greatly appreciated:
    QUESTION 1:
    Seems no matter what Quicktime codec and settings I use to capture with Snapz, the file always requires rendering, even when importing into FCP with identical timeline settings. Is this a limitation of FCP 3, or am I doing something wrong?
    Snapz/QT Capture settings:
    Video:
    – Sorensen Video 3
    – 15 fps
    – Keyframe every – 500 frames
    – Quality – Medium
    Audio:
    – IMA: 4:1
    – 22kHz, mono, 16-bit
    FCP Timeline Preset settings:
    – Framesize: Custom (739×513)
    – Pix aspect: Square
    – Field dominance: Unknown (not set)
    – Editing timebase: 15
    QT Video settings:
    – Compressor: Sorensen Video 3
    – Quality: 50%
    QT Audio settings:
    – Rate: 22.050
    – Compressor: None (no options to chose from)
    – Size: 16-bit
    – Use: Mono
    One peculiar thing I notice is when I check the clip’s Item Properties from the FCP browser, FCP shows the video rate as 10 fps, although as I mention above, I set it to 15 fps when capturing?!
    QUESTION 2:
    After editing and rendering the videos, I export as a Quicktime Movie and get nothing but a blank white screen for the duration of the video. FYI, I’ve confirmed that Range Check is off. I would list all of the Export Settings, but it seems to happen regardless of the settings I select. I can however export as a self-contained FCP Movie without a problem.
    Thanks in advance for any/all help.
    Regards!
    G4 : OSX 10.4.1 : 800MHz : 512 MB : FCP 3
    Jerry Hofmann replied 21 years, 2 months ago 2 Members · 1 Reply
  • Jerry Hofmann
    July 29, 2005 at 2:22 am
    I’ll bet that “Medium” in SnapZ doesn’t equal 50%… might try a different codec that you KNOW you can match exactly in FCP…
    Jerry
