Problem linking “SOME” AMA volumes
Hi everyone,
I’m linking C300 footage via AMA, to then consolidate it to mxf files.
But when I go “Link to AMA volume” and select the memory card folder, only one of the folders gets “imported”For example, there 3 folders:
CONTESTS
CONTESTS2
CONTESTS3and just the files in “CONTESTS” get imported.
However, I can use the “Link to AMA FILES” function, and I can individually import all the other files.
But it’s a much longer process…Any ideas on how to import the other folders as VOLUMES as well?
Thanks a lot!
