Activity › Forums › Adobe After Effects › Problem lighting a vector layer that has a color change effect applied
Posted by Lucas Gray on January 23, 2014 at 10:21 amHello,
I’ve got a vector line imported from Illustrator which I put a color change effect on (it was black to begin with).
Now it won’t accept the lights I’ve put in the shot but stays at 100%, even though everything around it is dimly lit.
LucasRoland R. kahlenberg replied 12 years, 8 months ago 2 Members · 7 Replies -
January 23, 2014 at 5:02 pmYou must have switched on the AI layer’s Continuously Rasterize switch. 3D Layers with CR do not react to Lights and its effect – shadows etc. They also break 3D interactions, intersections and Light effects.
So, double check to ensure that you really need to CR the AE file. If you do, then precomp the AE file and CR and scale up in the precomp. In the ‘final comp’, DO NOT CR/CT this nested comp.
HTH
RoRKIntensive mocha & AE Training in Singapore and Other Dangerous Locations
Imagineer Systems (mocha) Certified Instructor
& Adobe After Effects CS6 ACE/ACI -
January 23, 2014 at 5:21 pmMore details here on 3D Layers and CR/CT –
https://helpx.adobe.com/after-effects/using/3d-layers.html#3d_layer_interactions_render_order_and_collapsed_transformationsHTH
RoRK
AE MoGraph Intensity Workshop – Promo VideoIntensive mocha & AE Training in Singapore and Other Dangerous Locations
January 23, 2014 at 6:11 pmPlease get the CORRECT details here – https://helpx.adobe.com/after-effects/using/3d-layers.html#3d_layer_interactions_render_order_and_collapsed_transformations.
The info I provided in my first post is incorrect. 🙁
Cheers
RoRK
Lucas Gray
January 27, 2014 at 6:01 amThank you Roland,
I’ve read the article you cited and still can’t seem to get what I need.
When I pre-comp the Illustrator layer with its layer style (color overlay) it’s either too blurry without the CR switch on, or if I turn the CR switch on it’s just like it was back in the main comp: sharp, but unaffected by the lights.
I’m simply trying to animate a black line into a pale yellow line while retaining the lighting environment. It doesn’t seem so audacious!
Anyway, thanks so much for your response,
Lucas -
January 27, 2014 at 6:49 amLucas, post your AEP here – ZIP it up first. I think it’ll be much faster if I had a look at the file.
Cheers
RoRK
Lucas Gray
January 27, 2014 at 8:47 amHey Roland,
I didn’t see where you wanted me to post the file to. Also, I’m using a Mac, in case that makes a difference.
Lucas
January 27, 2014 at 12:41 pm[Lucas Gray] “When I pre-comp the Illustrator layer with its layer style (color overlay) it’s either too blurry without the CR switch on, or if I turn the CR switch on it’s just like it was back in the main comp: sharp, but unaffected by the lights.”
Layer Styles B-R-E-A-K 3D interactions in AE. Additionally, use the AI file directly in the ‘final comp’ – check the URL, again, I provided earlier.
Cheers
RoRK
