Problem Las editing tracks
Hi, I have an urgent problem and need to solve it because I have to submit a job and not get if not sooner under.
The problem is that every time I get a video track or photo or whatever to Las I edit tracks are blank. The point is that if reprodusco, I can view in the viewfinder, But I get all white strip, Both the video and sound. This happened after having risen PAR Files and while being loaded in the edit track I canceled the charge because he knew he was going to remove immediately.. I rebooted the computer and still not making me any file that you upload to edit.. Not to do and I'm not intentanto reinstall the program, I want to see if there is an easier exit.
Now thank you very much
Deborah.
