Activity › Forums › Avid Media Composer › Problem – Jerky Stills (jpeg) animation
  • Problem – Jerky Stills (jpeg) animation
    Posted by Anderson Black on February 14, 2009 at 4:28 pm
    I just did a basic animation on a still jpeg image – basically I keyframed the Scaling. But when it animates the movement is jerky. How do I fix this.
    i.e. I’m scalling a 720×480 jpeg from 100% to 70% over 3 secs duration. It’s supposed to scale down smoothly but it’s jerky.
    Thanks.
    Michael Hancock replied 17 years, 7 months ago 3 Members · 2 Replies
  • Grinner Hester
    February 19, 2009 at 12:33 am
    You have to do it in After Effects.
    Avid’s DVE is still a joke, man. It’s been this way since ’95 when the 3D DVE was released with MCv5.
  • Michael Hancock
    February 19, 2009 at 3:01 pm
    Are you seeing Red lines show up on your timeline? If so, you’ll need to render the effect. Otherwise, select your keyframes and adjust the Acceleration on them. It will help ease in and out of your moves and should smooth playback.
