Activity Forums Avid Media Composer Problem in RGB Monitor (Avid Media Composer Adrenaline)
  • Problem in RGB Monitor (Avid Media Composer Adrenaline)
    Posted by Abulazm on May 23, 2007 at 10:41 am
    Hi ….
    First of all i want to tell you all the information you need.
    workstation xw8200
    2 GB Ram
    Quadro FX 1400 128 Ram …. latest driver
    Avid Media Composer Adrenaline 2.1.6
    Dualview
    i’ve problems anyone can you help?
    1-when you pause … RGB monitor stop and back for one frame.
    2-playing in the edit and perview screen … change the color for five frames and do the same when pause.
    3-what is the ideal Hrtz for monitors.
    thank you in advance.
    Abulazm replied 19 years, 3 months ago 2 Members · 2 Replies
  • Michael Phillips
    May 24, 2007 at 1:01 pm
    Check out the Avid Knowledgebase for the color shift problem. This is an issue with the overlay of the graphics card and you can adjust the color via the Advanced settings of the card itself. Check the knowledgebase for the starting values that you can use.
    Michael
    anything 24fps
  • Abulazm
    May 25, 2007 at 3:24 pm
    thanks for you advise.
