Activity Forums Live Events & Streaming Problem in rendering file size 2160×720
  • Problem in rendering file size 2160×720
    Posted by Esli Kaplan on December 18, 2012 at 7:43 pm
    Hi There,
    I created an animation in After Effects CS5.5 for a presentation with some video footage and images at 2160×720 size, no audio. I’m trying to render a quicktime file in H264 codex but every time it renders at 2000×720.
    I read most of the posts here and I see that there’s an issue for rendering files over 2000px. I got a little confused with all the complicated posts that use multiple projectors and synced videos.
    The Equipment that will be running my file is at 720p signal with 2 projectors and full screen size is 2160×760 quicktime file with H.264 codex.. It shouldn’t be as complicated but I couldn’t find a solution.. Any ideas?
    Oh I also tried to render in iMovie quicktime export option, that renders the correct size but the quality looks super crappy..
    Michael Sisko replied 13 years, 7 months ago 3 Members · 2 Replies
  • Ken Geary
    January 30, 2013 at 12:59 am
    I tried on my CS5.5, QT H264 output was fine @2160 X 720.
    Check your scaling options in the encoding options window, you may have a preset checked off at 2000 pixels.
  • Michael Sisko
    February 22, 2013 at 1:11 pm
    Are you still having this issue, how did you resolve it? What were you using for playback?
