Activity Forums Adobe Premiere Pro Problem in Prodad plugins usage
  • Problem in Prodad plugins usage
    Posted by Vivek Reddy on June 22, 2011 at 8:46 am
    I just installed prodad adorage ,vitascene and heroglyph . All work fine as individual software’s . But the point was for all of them to work in premier pro as plugins . Only vitascene shows up in premier pro CS5 as a plugin ,all others don’t come up .What is the problem ? And I have master collection . And hence the plugins when installed should work in after effects also . But AE pops up error saying adorage and heroglyph will not work . I have updated all the prodad plugins and even premier pro.
    -Thanks
    Vivek Reddy replied 15 years, 1 month ago 2 Members · 2 Replies
  • Kenn Schulz
    July 28, 2011 at 12:36 pm
    I had the same problem. Vitascene (64-bit) installs as a plug-in in Prem. Pro CS5, but error box keeps popping up stating that my graphics card is not capable of runnig Vitascene. I have an nVidia Quadro FX3800 (list $1100) card with the latest drivers (v275.65) also. I’m assuming the problem lies hidden in Premiere. I dunno. -KS
  • Vivek Reddy
    July 28, 2011 at 3:58 pm
    Hey Vitascene works properly with premier pro CS5 ,there is no problem in that ,may be you should try installing the 32-64service.exe file ,which makes it compatible ,because I too had error coming ,but after installing this ,it worked fine .
    And Its only heroglyph that will not work ,because its still only CS4 compatible .
