Activity Forums Adobe Premiere Pro Problem in Premiere
  • Problem in Premiere
    Posted by Von Thomas on October 16, 2016 at 5:23 am
    I have a weird issue, I’m exporting a XML roundtrip into Premiere from Davinci, and the color is not going as it should. Here is an exported screenshot of the exported look
    Here is the imported look inside Premiere
    When I import into Premiere I get this error message
    Can you tell me what I’m going wrong? If I import the XML back into Davinci, it looks good, but not in Premiere.
    Von Thomas
    DIT / On-Set Dailies Colorist
    Tero Ahlfors replied 9 years, 11 months ago 3 Members · 3 Replies
  • Massimo Alberto croce
    October 16, 2016 at 10:27 pm
    It seems you have some effects applyed from the translation from xml from resolve. Look at the clip effect editor, and see if any effect is applyed
    Massimo Alberto Croce
    Video Editor, Colorist, Pro Tools Editor
    massimoalberto.croce@gmail.com
  • Von Thomas
    October 17, 2016 at 5:33 am
    It seems that PP is putting a color correction on top of my color corrected timeline. Now trying to see how to disable the Lumetri color for the entire timeline. Thanks Warren Eagle for the info.
    Von
    Von Thomas
  • Tero Ahlfors
    October 17, 2016 at 9:27 am
    Are you replacing clips on an excisting timeline? If the corrections are per clip you can select all of them in the timeline and right click – remove attributes.
