Activity › Forums › Maxon Cinema 4D › problem in lights ( light kit pro v2 ) c4d r17
  • Brian Jones
    May 2, 2016 at 6:19 pm
    it’s not the Lights it’s the Global Illumination. GI has changed and improved since 2012. You can get the target image pretty close by changing GI to the Interior-Preview preset and changing the renderer to Standard. You can do the same thing with the Progressive Physical you had set up it just takes a lot longer (not that physical is bad, it’s not. But sometimes the same result is a lot quicker in the ‘other’ renderer.
  • Mohamed Mohamed
    May 2, 2016 at 7:18 pm
    the good thing i know why i cant get it .. the bad thing a lot of tutorials old
    so last thing
    how ican get light like this
    https://vimeo.com/83389942
    in this tutorial he get this light only by (physical sky + GL )
    #where i can get tutorials like this for r17
    #what i should learn mental render or veray render
  • Brian Jones
    May 3, 2016 at 1:41 am
    this is your scene with the settings he uses (which are in 17) at the end of the video. Interior – Preview (High Diffuse Depth) with the Maximum Depth set to 5 (though 16 works just fine and doesn’t cost any time).
    The only thing your scene is missing is the Physical Sky with the sun spun around so it comes in the window. (That’s taking out the GSG sun – just going for his look). There’s nothing else to it.
    His image is brighter because he has way more windows but it’s the same basic look
  • Mohamed Mohamed
    May 3, 2016 at 1:52 am
    thaaaaaaaaaaaaaaaank you this much better
    so what i should learn first mental render or vray render?
  • Brian Jones
    May 3, 2016 at 3:10 am
    don’t know myself, I use the Standard and Physical renderers but there are lots of people out there are using others.
  • Mohamed Mohamed
    May 3, 2016 at 5:40 am
    Thank you too much for your help this is help me alot
