Activity Forums Adobe Encore DVD Problem in Encore linking up to Photoshop
  • Problem in Encore linking up to Photoshop
    Posted by Kadshah Nagibe on November 28, 2011 at 4:23 am
    I watched Andrew Devis video “Adobe Encore Basics 2 Creating Menus”
    but I ran into a problem. I right click in project submenu then edit menu in photoshop but photoshop doesn’t come up instead I get a window that has file, edit, image and help that’s it. I have photoshop CS5.1 64bit installed but right clicking in encore doesn’t link up tophotoshop what should I do?
    -kaj
    https://sweetproductionmedia.com
    Kadshah Nagibe replied 14 years, 10 months ago 2 Members · 3 Replies
  • Clayton Brown
    November 28, 2011 at 6:33 pm
    Make sure that the menu you are saving and bringing into encore is a PSD- then when you import the file, make sure you ‘import menu’ –
    with the menu selected- click edit, then ‘edit menu in photoshop’ –
  • Kadshah Nagibe
    November 28, 2011 at 7:46 pm
    when i right click on NYSC project Submenu a menu comes which gives me the option of editing the menu in Photoshop I click on that photoshop is NOT loaded instead picture viewer is loaded. How can I get photoshop to load?
    -kaj
  • Kadshah Nagibe
    November 28, 2011 at 8:09 pm
    thanks Clayton for your help. I figured it out. Although I can’t get photoshop to load from within Encore I’m able to load it directly from the shortcut on my desktop.
    -kaj
