Activity Forums Adobe Premiere Pro Problem in Capturing and Quality issues.. Plz. help….
  • Problem in Capturing and Quality issues.. Plz. help….
    Posted by Anand on May 29, 2005 at 5:02 pm
    Dear Sirs,
    I have the following problems :
    1. I use Sony DCR-HC30E Digital Camcorder for taking movies.
    2. When I connect the camcorder to USB Stream and launch Premiere Pro 1.5 and the Capture (F5), there is no live buttons for me to capture the video. I am putting it simply, but rest assured, I have tried all possible methods to capture video. I am unable to start capture. Is there anything that I should firewire connection instead of USB ?
    3. However, I am able to download my videos into my PC using Windows Movie maker
    4. Secondly, after downloading the movie, the clips appear very dull lit, meaning, if I connect the camcorder directly on to TV, the display is excellent. I do not know why there is loss of quality.
    5. Lastly, I am planning to appear for ACE in Premiere Pro in a month’s time. Can someone guide me as to what and how I should study.
    I am really depressed. Please help.
    S. Anand
    aka Andy
    Adobe Certified Expert, Photoshop CS
    Anand replied 21 years, 3 months ago 3 Members · 3 Replies
  • Perry Cheng
    May 29, 2005 at 9:36 pm
    Mostly, USB connection is for capturing still images… you need to firewire connect for DV Capture.
    Yes, if the source is poor, even it may be viewed in the LCD mon as ok, because you turned up the brightness, the actual digital signal is still poor. Having that said, the only way to know for sure is to view the captured clip on external monitor, instead of your computer monitor. That means, you have to invest on heavy duty equipments or learn from you experience after trials and errors.
    Perry
  • Steven L. gotz
    May 29, 2005 at 9:50 pm
    Most people just connect a Monitor or a TV up while editing to check colors and brightness. If you connect the camera up to both the PC (firewire) and the TV (A/V out), you will have an easier time editing.
    Steven
    Adobe Premiere Pro 1.5 / After Effects 6.5 Pro https://www.stevengotz.com
    Learning Adobe Premiere Pro 1.5 https://www.lynda.com
    Contributing Writer, PeachPit Press, Visual QuickPro Guide, Premiere Pro 1.5
  • Anand
    June 4, 2005 at 8:26 am
    Thanks to you and Steve… the problem is sorted out.
    S. Anand
    aka Andy
