Activity Forums Adobe After Effects problem in AE camera
  • problem in AE camera
    Posted by Yousef Tannous on January 23, 2014 at 7:02 pm
    hi , i wish you could help me with this weird problem i encountered ! in my comp after i make a composition and want to add a camera , 3d effects like particular would animate in the first keyframe but as soon as i insert a new keyframe for the camera every 2d layer would animate regularly but 3d effects ( in my case particular) has’nt been affected!!
    thanks in advance 🙂
    Walter Soyka replied 12 years, 8 months ago 3 Members · 4 Replies
  • Yousef Tannous
    January 23, 2014 at 7:29 pm
    Thank you for your prompt response, ive tested with particle world and and the same thing happend, I can change the general camera view , rotate, track z etc.. but when I click the stopwatch and insert a new keyframe camera animation wont affect the 3d effect.. so I can conclude that its not particular specific problem but a camera one.. any ideas ???
  • Sam Freeman
    January 23, 2014 at 8:48 pm
    Do you have your disk cache enabled? If so try turning it off (preferences>media&disk cache>enable disk cache tickbox) and empty existing cache items.
    Some 3D effects don’t refresh the cache and show old frames rather than new…
  • Yousef Tannous
    January 23, 2014 at 10:07 pm
    Thank you for your response, I tried that but it didnt solve the problem ..
  • Walter Soyka
    January 24, 2014 at 5:17 am
    A couple of screenshots showing the problem would be helpful.
    It’s possible that your comp viewer is set to a custom view. If so, set it to Active Camera instead:
    [image]
    Walter Soyka
