Activity Forums DVD Authoring . Problem importing .scc file into dvdsp
  • . Problem importing .scc file into dvdsp
    Posted by Rick Tejada flores on December 11, 2017 at 8:38 pm
    When I try to import the .scc file it gives me “incompatible format” message. Its the right frame rate. What else should I check or do?
    Rick Tejada-Flores
    Christopher Smith replied 8 years, 5 months ago 2 Members · 1 Reply
  • Christopher Smith
    April 13, 2018 at 3:44 pm
    Hi Rick
    I’ve never seen that error message, so I have to guess what might be wrong. I would guess the software you’re using to produce the SCC file messed up somehow. I use Annotation Edit from Zeitanker.com, and if this happened to me, I would try a new export. Then I would try exporting the captions track that Annotation Edit produces when the Caption Test is run successfully; it always makes a new copy of the Captions track if there are no overflow errors, and the timecodes on that will be a few frames different, to optimize playback. Often, that Caption Test track works better than the human-produced one.
    Finally, I would try re-importing the problem SCC file into Annotation Edit, and then export a fresh SCC from that.
    Whenever I receive caption errors from DVDSP, it is on Build, not import of the SCC file, so I’m at a loss what could be the issue you’re experiencing.
    Christopher Smith
    CBN International
