Activity › Forums › Avid Media Composer › problem importing mxf op-1a into Media Composer 8.0
  • problem importing mxf op-1a into Media Composer 8.0
    Posted by Levan Birkadze on September 2, 2015 at 8:36 am
    I have Media Composer 8.0.0 installed
    I try to import mxf op-1a video file (exported from Premiere pro) using AMA link and it fails.
    I check the console and it says that the plugin is missing.
    I downloaded plugin from Avid website (https://goo.gl/6fwv7), but the installation failed as it does not support Media Composer 8!
    is there any solution to import mxf op-1a files into MC 8?
    p.s. I am new to avid
    thanks!
    Massimo Alberto croce replied 11 years ago 2 Members · 3 Replies
