Activity › Forums › Apple Final Cut Pro Legacy › Problem: Importing C300 file (long, spanned clip won’t import, others will) FCP7
  • Problem: Importing C300 file (long, spanned clip won’t import, others will) FCP7
    Posted by Willem Kort on February 5, 2013 at 1:46 pm
    Hi all,
    I have a problem when importing a C300 file through FCP’s Log & Transfer.
    When I add the ‘CONTENTS’ map to the Log & Transfer window, it will skip one of the files. It will not show it in the window. This is a spanned clip, in total about 30 min. Other spanned clips from the same card/map are imported without a problem. The files in the map look the same as the files in the corrupted map.
    The person who asked me to help her out, says she has tried to open it in XDcam Transfer. Might this have corrupted the files (metadata?)
    Anyone any ideas how to solve this?
    Thanks a lot!
    Shane Ross replied 13 years, 7 months ago 2 Members · 1 Reply
  • Shane Ross
    February 5, 2013 at 5:56 pm
    Does the clip happen to span to a second card? Wait, C300 only has one slot, right?
    Look at Calibratedsoftware.com and their software that enables FCP to look directly at the MXF file. See if you can use that to see the clip, and then transcode it with Quicktime or something. A demo is available.
    Shane
    Little Frog Post
