Activity Forums Maxon Cinema 4D problem highlights pop on/off
  • problem highlights pop on/off
    Posted by Roy Mckenzie on September 3, 2014 at 2:33 pm
    This is kind of annoying the material in combination with the way my polygon moves is causing highlights to pop on and off quickly. I think I understand why it is happening, but I’m not sure how to eliminate or at least reduce it. Correct me please if I’m wrong, but it seems to happen as a flat surface become perpendicular with a light source.
    I included a sample movie in the link below. I need to create this look with hard-lined polygons, but I hope I can get rid of the highlights popping on/off.
    Example: look for the white highlights the pop on/off in a matter of 1 or 2 frames:
    https://bigpict.com/misc/c4d/insight2014_shapes_v01_stg023.mov
    I did a render last night with no material at all and highlights still pop on/off. See the link below.
    Im starting to wonder if it is a polygon issue. Anyone else ever notice how when polygons overlap sometimes it causes weird things like artifacting and such? I would love to know what causes that and if it is correctable too.
    https://bigpict.com/misc/c4d/insight2014_shapes_v01_stg024.mov
    Roy Mckenzie replied 12 years ago 2 Members · 2 Replies
  • Adam Trachtenberg
    September 3, 2014 at 3:18 pm
    Do you have a phong tag on your object? If so I would delete it. It can cause shading errors as neighboring polygons pass through the set phong angle.
    If that doesn’t do it I would use a material with the specular channel turned off.
  • Roy Mckenzie
    September 3, 2014 at 6:11 pm
    It was the phong tag, funny I was trying to mess with that. I had the angle set to “0” so I could get the hard surfaces. I come out about as good with it gone though, so many thanks!
    Thank you
    Roy
