Activity Forums Apple Final Cut Pro Legacy Problem Frame rate change after export
  • Problem Frame rate change after export
    Posted by Troy Gordon on August 13, 2010 at 9:09 am
    So this has been ticking me off for the past 9 hours,
    I have a project all finished up in final cut pro but its in 29.97 frames per second, (timeline and original footage) but whenever i export it its 24 frames or some other frame rate. The footage basically looks all ghosty and the movement isn’t smooth as the preview window. I check all the compressor settings, timeline settings and source footage settings a million times and i still get the same result when i render.
    does anyone know whats going on here?
    ps
    I also tryed compressor and nothing changed
    thanks guys
    Cheers
    TG
    Troy Gordon replied 16 years, 1 month ago 1 Member · 0 Replies
  • 0 Replies
