Activity › Forums › VEGAS Pro › Problem finding a render template in VP11.0
  • Problem finding a render template in VP11.0
    Posted by Martin Seemungal on October 13, 2012 at 10:18 am
    I recently switched from Sony Vegas 10.0 to 11.0–the most recent version.
    In Sony Vegas 10.0 under the Sony AVC/MVC templates there is one called: Internet 1920x1080p 30p and a few other ‘internet’ settings under that general template.
    In Sony Vegas 11.0 i can’t find any of the ‘internet’ templates under the Sony AVC/MVC general template. Is there are reason for this? have they been moved to a different place in the render options?
    Martin Seemungal replied 13 years, 11 months ago 3 Members · 4 Replies
  • Mike Kujbida
    October 13, 2012 at 3:31 pm
    I don’t have 11 on my home machine but I believe they were moved to to the MainConcept template.
  • Martin Seemungal
    October 14, 2012 at 1:43 pm
    Thanks. You are correct that it is under the Mainconcept template–I had already managed to navigate there but when i tried to render i kept getting ‘there was an error encoding xyz.mp4, reason for error could not be determined’…
    After some trial and error with the settings I discovered I had to change the setting at the bottom related to ‘encoding’ from ‘automatic’ to CPU Only… now it works fine.
  • Joseph Tessier
    October 14, 2012 at 2:35 pm
    Mike is correct, Main Concept “Internet HD 1080p”.
    For me upgrading from VP 10 to 11, this was a step backwards. I could never get the VP 11 template to perform quite as well as VP 10. In fact, I still use VP 10 at times. Sometimes the VP 11 is satisfactory for my needs.
    J. Paul
    System Specs: I7 3.4 Ghz Quad Core 16GB Ram Win 7 Home Prem x64 VegasPro 11 NVIDIA GeForce GTX 550
  • Martin Seemungal
    October 14, 2012 at 4:45 pm
    I have solved the problem by Updating the driver on the Nvidia graphics card. Now I can leave the ‘encode’ on automatic and its fine.
    Does anyone know anything about the ‘deblocking filter’ ?
    When I use the Mainconcept AVC i see that it is checked and that a value of ‘1’ is there as default.
    In V10 the mainconcept seems to have a value of ‘2’… does this matter…? what is best setting regarding this and is ‘checking’ or enabling it important?
    thanks
