Activity › Forums › Adobe Premiere Pro › Problem Exporting With Still Image
  • Problem Exporting With Still Image
    Posted by Greg Burke on August 12, 2013 at 11:16 pm
    Hey All, so I export an intro segment for my client, but the Image Flickers, Its not because its interlace, it looks different than interlacing. In the timeline it plays back, it appears fine, I’ve tried using PNG, and the same thing happens after export, Any thoughts? A Example is below as is the export settings.
    https://www.youtube.com/watch?v=2sFVrQEr3I0
    0:04-0:10
    Export settings
    1920×1080
    23.976 fps
    Progressive VBR
    2 pass
    Target 5.00mbs
    Max 6.00mbs
    4800 hz, Stereo
    I wear many hats.
    http://www.gregburkepost.com
    Ivan Myles replied 13 years, 1 month ago 4 Members · 5 Replies
  • Ivan Myles
    August 13, 2013 at 4:18 am
    Are you referring to the white text from 00:06-00:11?
    In general, 5Mbps is relatively low for 1920×1080. Does the issue exist at higher bitrates?
  • Greg Burke
    August 13, 2013 at 6:08 am
    No mainly the Banner, with the artist picture looks flickery
    I wear many hats.
  • Ann Bens
    August 13, 2013 at 12:21 pm
    Try flicker removal in the Field Options for banner as the text also jumps.
    Adobe Certified Expert Premiere Pro CS6
    Adobe Community Professional
  • Jeff Pulera
    August 13, 2013 at 2:17 pm
    Serif fonts, with their fine tails, have always been problematic for video. Better to use Sans-serif when possible.
    Try using Photoshop to add a tiny bit of Gaussian Blur, maybe 0.2 and see if that makes a difference. That has always helped when I add motion to stills and get flickers in the details, though your image is not moving, I know.
    Jeff Pulera
    Safe Harbor Computers
  • Ivan Myles
    August 13, 2013 at 6:31 pm
    For the same reasons Jeff describes, the results will probably be better using Title Designer if the text was imported as an image file. Also, I have found that native Photoshop and Illustrator files work better than png/jpg images as long as the psd/ai files are not resized.
