Activity Forums Apple Final Cut Pro Legacy Problem exporting with compressor.
  • Problem exporting with compressor.
    Posted by Jake Scott on April 19, 2009 at 8:27 pm
    When I use compressor to export my sequence from FCP, I use DVD best quality 90 minutes option. When I click submit I get a message that says:
    Cannot submit batch
    Unable to connect to background process
    Can anyone help me out with this? I have a project due in less than a week and I just need to get it onto DVD. Thank you
    Compressor version 2.0.1
    FCP version 5.0.4
    Jake Scott replied 17 years, 5 months ago 3 Members · 5 Replies
  • William Carr
    April 20, 2009 at 6:30 am
    Try exporting a Quicktime of your sequence using “Current Settings”.
    Then bring the resulting standalone Quicktime file into Compressor, without involving FCP.
  • Rafael Amador
    April 20, 2009 at 8:32 am
    Reinstall the “Apple QMaster” that comes with your Compressor.
    Don’t install a newer version.
    rafael
    http://www.nagavideo.com
  • Jake Scott
    April 20, 2009 at 1:25 pm
    Would upgrading to Final Cut Studio 2 alleviate this problem? Ever since I purchased my new MacPro, Final Cut Studio has been acting up. I never had these problems when I was editing on my iMac.
  • Rafael Amador
    April 20, 2009 at 2:56 pm
    Hi Jake,
    If you are running an Intel Mac you should be using, at least, FC 5.1.
    The FC version you are using is for PPC processors.
    You are running FC through an intermediate software (Rosseta) that allows the Intel processor to run applications wrote for PPC processors.
    I think is time to update. Sure you won’t regret.
    FC 6.05 with QT 7.6 are working quite well.
    rafael
  • Jake Scott
    April 24, 2009 at 6:51 pm
    Just a heads up…I upgraded to Final Cut Studio 2 and all my problems were fixed. Thanks for the help!
