Activity Forums Maxon Cinema 4D Problem Exporting to After Effects
  • Problem Exporting to After Effects
    Posted by Dwayne Neveu on June 25, 2011 at 7:00 pm
    Hello Everyone! This is my first post.
    I have exported a project from C4D R12 to After Effects CS5.
    I created 2 planes on my object and applied the compositing tag with object buffers and external compositing.
    When I open the project in after effects, the plane doesn’t follow the rotation of the object.
    I’m not sure what I’ve done. I’ve uploaded the file so you can see it.
    2478_jf.c4d.zip
    Hope you can help me….
    Shawn Dunbar replied 15 years, 2 months ago 3 Members · 4 Replies
  • Adam Trachtenberg
    June 26, 2011 at 2:23 pm
    You should set your planes to XY axis in Cinema so the Z axis is facing out.
  • Dwayne Neveu
    June 27, 2011 at 11:49 am
    Thanks for that, will try when I get back in the office, and let you know the result
  • Dwayne Neveu
    June 27, 2011 at 3:22 pm
    Still same problem, not sure what I’m doing wrong.
    The planes last longer than the animation, but im guessing thats the frame rate.
    Here is a video of what’s is in AE 2488_jf.c4d.mp4.zip
  • Shawn Dunbar
    June 29, 2011 at 8:20 pm
    You’re exactly right in that it’s frame rate related. Right click on your footage that was imported when you brought in the aec file, and interpret it to be 25 frames per second. You’ll see it’s currently at 30fps.
    Shawn
    https://www.dunbox.com
