Activity › Forums › Apple Final Cut Pro Legacy › problem exporting quick time from final cut
  • problem exporting quick time from final cut
    Posted by Bilenera on March 5, 2006 at 10:45 am
    hi to all…
    i notice a big problem with final cut export…
    i had to export a quick time file from a project to work on the video with another softwere…
    i make a quick time file with the quick time conversion tool…setting no compression etc…
    the file i make is different from the original…
    is a problem about settings or is usual?
    with premiere…making avi files this problem is not detected…
    can someone explain me this thing?!?!
    thenks
    mauro
    Jerry Hofmann replied 20 years, 7 months ago 2 Members · 3 Replies
  • Jerry Hofmann
    March 5, 2006 at 3:51 pm
    Try exporting a non self contained QT movie instead. That way the file is actually referencing the original media. If you export using QT conversion, you recompress every time.
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
  • Bilenera
    March 5, 2006 at 11:07 pm
    you mean to export with the “export quiqk time”?!?!
    and i can use this file with other software…burn it…and so on?
    thanks…
    i’ll try…
    mauro
  • Jerry Hofmann
    March 6, 2006 at 8:55 pm
    yep…
    Jerry
