Activity Forums Apple Final Cut Pro Legacy Problem exporting EDL
  • Problem exporting EDL
    Posted by Paul Leone on May 19, 2005 at 7:19 pm
    This is a strange problem I have no answer for…I have 5 sequences that I need EDL’s printed out for, but sequence 4 will not export. All the others are fine but Sequence 4, nothing! No matter what i do, create a new sequence and paste sequence 4 into it reneame it etc…still nothing. Any ideas?
    Paul
    CMX 3600 is what I’m trying to do
    Bryan Shelton replied 21 years, 3 months ago 3 Members · 2 Replies
  • Rienk Leendertse
    May 20, 2005 at 8:29 am
    Try to copy parts of the sequence and make EDL’s from that.
    That will help you to find the problem.
    Also never export more than 4 audiochannels per EDL
    never export more than one videotrack per edl (use Target Video Track Only)
    So a sequence with 3 videolayers and 8 audiotracks will produce 3 edl’s:
    v1 +a1234
    v2 +a5678
    V3
    Also
    speedchanges higher than 300% can be troublesome
    graphics can be troublesome
    All the best
    Rienk
  • Bryan Shelton
    June 15, 2005 at 5:01 pm
    If you have any freeze frames which are from a sequence and not from the original media, the edl export fails. It never even warns you that it will fail nor gives you a reason.
