Activity › Forums › Adobe Premiere Pro › Problem Exporting Cineform Project in CS3
  • Problem Exporting Cineform Project in CS3
    Posted by Brian Schmidt on August 28, 2009 at 6:14 am
    I’m working on a windows XP professional and running premiere pro CS3. When I try to export a cineform project as a quicktime movie with h264 compression, it comes out as a white and magenta colored image of the file. It comes out that way with most export options, but if I export it as a cineform quicktime with cineform compression, it puts the new file in my bin and then that file causes premiere to crash. Same thing for cineform avi.
    If I look at the bad file in whatever folder I have put it, it will freeze the computer after a few seconds of seeing it. I’ve tried for the life of me to try to figure out what’s wrong and can’t seem to do anything. First had it on vista, but then cleaned out computer and reinstalled everything on XP.
    Brian Schmidt replied 17 years, 1 month ago 2 Members · 2 Replies
  • Mike Velte
    August 28, 2009 at 10:20 am
    What version of QT are you using? Some versions have caused serious issues with Premiere. I am using 7.3.1 and all is well.
  • Brian Schmidt
    August 28, 2009 at 4:20 pm
    I’m using the most up to date version of QT, but its not just QT. If I render it out at an AVI it still comes out as magenta colored.
