Activity › Forums › Apple Final Cut Pro Legacy › Problem exporting
Problem exporting
Posted by Emmanuelle Lorin on March 23, 2009 at 10:41 amHi everyone,
I am having problems outputting my film in FCP 6.
I have a smaller drive with little space in my system drive but have tons of space in the external designated drive for output. When exporting the movie, it starts out exporting fine and about an hour into it the program sends a message saying my system drive (the smaller one) is completely full and it doesn’t allow me to finish exporting the movie into the external one.
Do I need to have the same amount of space in both drives (the one where the system/program is and the external one)? Does anyone have any ideas to resolve this problem?
Thanks.
Emmanuelle Lorin replied 17 years, 6 months ago 3 Members · 8 Replies -
Rafael Amador
March 23, 2009 at 12:04 pmHi Enmanuelle,
By any chance is your external HD formated as FAT32?
Rafael(and here some clips for the friends: https://www.vimeo.com/2694745 )
Some contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
Zane Barker
March 23, 2009 at 4:24 pmEven though you are chose the external drive as the place to save the file to, it is still important to have plenty of free space on the system drive. This is because as the computer is working it writes temporary times to the internal (and with video those temporary file can get large).
ALWAYS ALWAYS ALWAYS leave 10-15% of your system drive free if not more.
There are no “technical solutions” to your “artistic problems”.
Don’t let technology get in the way of your creativity! -
Emmanuelle Lorin
March 23, 2009 at 8:24 pmHi Rafael,
I don’t think so as when the Mac first installed it, it would have formatted it in Mac format no? But it is a drive that takes both Mac and PC systems.
Thanks.
Emmanuelle Lorin
March 23, 2009 at 8:46 pmSo basically, I do need the same amount of space in the system drive? Thanks!
Rafael Amador
March 23, 2009 at 11:20 pm[Emmanuelle Lorin] ” But it is a drive that takes both Mac and PC systems. “
If is formated for PC and Mac: THEN IS FAT 32.
You can not edit with a drive like that because you can not manage files bigger than 4 GB.
You need format the HD as MacOS Extended (NO Journaled).
Emmanuelle Lorin
March 24, 2009 at 4:42 amHi Rafael,
Thanks for prompt reply. I am looking at it and the big drive is formatted MacOS Extended. The system drive (smaller) is formatted MacOS Extended (Journaled). Is there something wrong with this?
Best!
Rafael Amador
March 25, 2009 at 4:39 pmHi Emmanuelle,
Sorry I’ve been far from internet the last three days.
There is some contradiction in your information.
If your HDs are formated as MacOs Extended, thas correct.
But in this case they can not be managed by a PC unless you use MacDrive or any other application that allows PC to control Mac formated HDs.
One of your HDs is Journaled. Normally is recommended “no Journaled” for media drives. However this is can not be the cause of your problems when exporting.
Cheers,
rafael(and here some clips for the friends: https://www.vimeo.com/2694745 )
Emmanuelle Lorin
March 27, 2009 at 4:53 amHi Rafael,
There is no “pc” involved if you are referring to a nonMac computer.
The drive’s instruction said to do it journaled…
I checked for viruses, spyware and it found none. However, out of the sudden the computer started kind of “reloading” and taking you from FCP to the Finder window, whether you wanted to or not. I have Tiger in my system and once I added a program called Mac OSX Planet (now removed). Do you know of any program like Conflict Catcher?
E
