Activity › Forums › DVD Authoring › Problem encoding/authoring movie with subtitles
  • Problem encoding/authoring movie with subtitles
    Posted by Russ Burgess on April 18, 2013 at 5:37 pm
    I am having trouble authoring a master DVD from my 70 minute 30frame ProRes movie file.
    When I export from the timeline in FCP7, the file and subtitles look perfect. I then use compressor to encode to the mpeg2 media using the DVD: BEST QUALITY 90 MINUTES setting.
    The result is that the image and motion of the movie becomes horribly interlaced (unwatchable) – and the subtitles look solid.
    I then reused compressor – changing the output field to PROGRESSIVE (resize, deinterlace, rate conversion set to BETTER). The result is now the image looks perfect, but the subtitles look like shit – really flimsy and almost flicker when there is movement behind them to the point where its distracting.
    Clearly I am no pro with this – anyone have any thoughts or solutions?
    Thanks in advance
    Daniel Ludwig replied 13 years, 5 months ago 2 Members · 1 Reply
  • Daniel Ludwig
    April 19, 2013 at 6:24 pm
    Russ,
    you couldn´t give less informations on your project.
    what is you sequenz-codec? what framerate? size? what is the original-codec of your footage?
    how did you implement the subtitle into the DVD? using DVD Studio Pro with STL-text?
    or did you use FCP-text-tool and render out the text “burned in” into your final video?
    cheers
    danny
