Activity Forums Adobe Media Encoder Problem encoding Quicktime Mov with Adobe Media Encoder
  • Problem encoding Quicktime Mov with Adobe Media Encoder
    Posted by Timo Koljonen on September 24, 2011 at 7:11 pm
    I have a MOV-file which has been exported from Final Cut. I edited it in Premiere CS 5.5 and then tried to export again to Quicktime Mov. Problem is that the output look terrible. There is some kind of “Motion bluriness” or fuzziness in the video and looks like there is a maybe frame rate problem.
    Does anyone know what the problem is? I use “real” Quicktime from Apple website.
    Here is the information of my Premiere project:
    Editing mode: DV PAL
    Timebase: 25,00fps
    Video Settings
    Frame size: 720h 576v (1,4587)
    Frame rate: 25,00 frames/second
    Pixel Aspect Ratio: D1/DV PAL Widescreen 16:9 (1.4587)
    Fields: Lower Field First
    Here is the information (Mediainfo) of the original MOV:
    Format : MPEG-4
    Format_Commercial_IfAny : DVCPRO
    Format profile : QuickTime
    Codec ID : qt
    File size : 2.06 GiB
    Duration : 9mn 42s
    Overall bit rate : 30.3 Mbps
    Encoded date : UTC 2011-08-17 18:12:37
    Tagged date : UTC 2011-08-30 17:05:26
    Writing library : Apple QuickTime
    ©TSC : 25
    ©TSZ : 1
    Video
    Format : DV
    Codec ID : dvpp
    Codec ID/Hint : DVCPRO
    Duration : 9mn 42s
    Bit rate mode : Constant
    Bit rate : 24.4 Mbps
    Width : 703 pixels
    Original width : 720 pixels
    Height : 576 pixels
    Display aspect ratio : 16:9
    Frame rate mode : Constant
    Frame rate : 25.000 fps
    Standard : PAL
    Color space : YUV
    Chroma subsampling : 4:1:1
    Bit depth : 8 bits
    Scan type : Interlaced
    Scan order : Bottom Field First
    Compression mode : Lossy
    Bits/(Pixel*Frame) : 2.414
    Stream size : 1.95 GiB (95%)
    Language : English
    Tagged date : UTC 2011-08-17 18:15:18
    And here is the information about exported video:
    Format : MPEG-4
    Codec ID : qt
    Duration : 9mn 42s
    Encoded date : UTC 2011-09-24 19:59:53
    Tagged date : UTC 2011-09-24 20:01:56
    ©TIM : 00:00:00:00
    ©TSC : 25
    ©TSZ : 1
    Video
    Format : DV
    Codec ID : dvcp
    Duration : 9mn 42s
    Width : 720 pixels
    Height : 576 pixels
    Original display aspect ratio : 4:3
    Standard : PAL
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Bits/(Pixel*Frame) : 2.357
    Language : English
    And final information about my computer:
    CPU
    Intel(R) Core(TM) i5-2500K CPU @ 3.30GHz
    RAM
    8.0 GB
    OS
    Microsoft Windows 7 Service Pack 1 (build 7601), 64-bit (Professional)
    Video Card
    AMD Radeon HD 6900 Series
    Timo Koljonen replied 14 years, 11 months ago 1 Member · 0 Replies
  • 0 Replies
