Activity Forums AJA Video Systems Problem digitizing composite signal with IO
  • Problem digitizing composite signal with IO
    Posted by Y12video on November 21, 2005 at 12:06 pm
    I’m trying to digitize some old 3/4″ footage from a Sony deck into Final Cut, and I keep having this one problem that I can’t overcome. I can control the deck in FCP, but it will not show the video on the preview monitor in the capture tool. The IO box is showing the correct lights (composite, firewire, ntsc), and I have no problems controlling it any way I need. I have current drivers, and I have the AJA control panel v 1.1. Any ideas? Is this a Final Cut problem or AJA?
    Thanks.
    Y12video replied 20 years, 9 months ago 2 Members · 4 Replies
  • Frank Nolan
    November 21, 2005 at 7:03 pm
    Do you have the correct capture settings in the Audio/Video settings menu? As there is a huge selection it’s easy to get them mixed up. If they are right, sometimes it pays to select something different and hit OK then go back and re-select the one you need.
  • Y12video
    November 22, 2005 at 11:20 am
    Yeah, I’m certain that I have the right settings.
    Control: AJA IO RS-422 NTSC
    Capture: AJA IO 8-bit composite to US NTSC DV
    I’ve tried multiple varieties of combinations with different composites. I’ve also tried selecting different settings and opening and closing Final Cut. I’ve also rebooted the G5 many times. It’s always the same.
  • Frank Nolan
    November 22, 2005 at 9:50 pm
    Hmmm best start with some basic troubleshooting. Cables first. If you connect the video out cable from the 3/4 deck to a monitor instead of to the AJA, are you seeing picture on the monitor? Do you have blackburst being sent to the 3/4 and the AJA? Does it need to be terminated? Have you ad previous success capturing with the AJA in any other modes?
  • Y12video
    December 1, 2005 at 11:54 am
    Thanks for the tips. We figured it out. It was some more settings in FCP that we hadn’t tried. We didn’t realize that you needed to set the video playback as well to get a signal displaying in log and capture. Seems kind of wierd to me, but oh well.
