Activity Forums VEGAS Pro Problem deinterlacing HDV in sony vegas 9 platinum
  • Problem deinterlacing HDV in sony vegas 9 platinum
    Posted by Chris Nana on July 14, 2009 at 5:53 pm
    Having switched over to High Definition i am now seeing serious issues regarding playback of my HD files (m2t files) on my PC.
    Any movement is accompanied by scan lines across the screen…a problem that i read is related to interlacing.
    I tried to deinterlace clips using both the blend and interpolate methods under project properties (rendering to both avi and mpeg2 files) with no effect.
    Only the ‘reduce interlace flicker’ option worked (under right click – ‘switches’)
    My concern is that this option may not be as effictive as the blend or interpolate methods. Maybe i’m losing more picture quality than necessary?
    So my questions are:
    1. Why are ‘blend’ and ‘interpolate’ features not making any difference to my interlacing issue. Am i missing something when rendering?
    2. Is ‘reduce interlace flicker’ a viable alternative without degrading picture quality unnecessarily?
    I’m eventually looking to output on to dvd, viewers could be watching this on any type of tv or PC (so i will have to deal with the interlace problem now)
    I used a canon HV30 to capture in HDV 1080i mode.
    John Rofrano replied 17 years, 1 month ago 2 Members · 1 Reply
  • John Rofrano
    July 15, 2009 at 1:56 am
    Then there is nothing you have to do. The interlacing that you are seeing is normal and expected. Ignore it. If you don’t like it, get an analog studio monitor and feed it from a firewire signal. Your PC monitor is not interlaced so it doesn’t know what to do with the two fields and it displays the lines that you see. A TV is interlaced and it will know exactly what to do with the two fields and display without the lines. Likewise the DVD played back on any PC will not have the lines because the DVD player software is smart enough to deinterlace the footage for you. The only time you need to deinterlace is when preparing video for the web or PC files (not on DVD).
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
