Activity › Forums › VEGAS Pro › Problem Creating CD from timeline audio
  • Problem Creating CD from timeline audio
    Posted by John Perez on May 5, 2013 at 12:29 am
    I burn the cd, it’s says it’s successfully burned, then when I put it in my CD player it plays the first few seconds of the first track and then the sound vanishes. I check the following 12 tracks and all are silent. Any ideas? Thanks
    As always thanks so much to you guys…Johnny In Orlando
    Wayne Waag replied 11 years, 1 month ago 5 Members · 5 Replies
  • Stephen Mann
    May 6, 2013 at 3:15 am
    What format did you encode to? I recommend the investment into CD Architect which does a really good job of making an Audio CD.
    Steve Mann
    MannMade Digital Video
    http://www.mmdv.com
  • John Perez
    May 6, 2013 at 11:43 pm
    From the Vegas 10 timeline for CD burn.
  • Dave Tong
    August 19, 2015 at 3:29 am
    FWIW, I experienced this same problem. I tried three times with similar results. So I moved the project to a different machine and the CD burned correctly and all the tracks play.
  • Danny Hays
    August 19, 2015 at 3:43 am
    Problem with the burner or it’s driver? Do you have a different machine to try it John?
    Danny Hays, Also from Orlando. 😉
    Danny Hays
    Samples of my Work can be seen here:
    https://www.youtube.com/user/ErnestDaniels/videos
  • Wayne Waag
    August 19, 2015 at 8:05 pm
    IMHO, a better solution. Render your audio to a wav file(s). Use the freeware Imgburn to create CD image and then burn. This approach works for CDs, DVDs and Blu-rays. My own rule of thumb has been to never use the “burning” part of any application. Create the image file, yes, but always burn with Imgburn. Never a problem. Just a suggestion.
    wwaag
