The .m2ts files on my discs will play fine for the first 15-16 minutes, then have terrible frame rate issues (choppy, stuttering video, sometimes briefly sped up) for the remainder.
Not sure what would cause that. The PS3 can play just about anything. I suspect you’ll get in trouble if you’re rendering higher bitrate video to DVD. But if this is to Blu-ray, you should not see performance problems.
Here’s what I’m doing: The original .m2t clips are compiled into .vf files, rendered as Sony AVC files with default options. (PC limitations prevent the creation of files larger than 30 minute runtime.) I then use Nero 8 Burning ROM to create a UDF BD compilation of multiple .m2ts files.
You have done the equivalent of rendering a .mpg file and then burning it onto a DVD. You can use .m2t, .avc, or .mp4 files to create a Blu-ray disc, but the disc compilation is much more than that. And Blu-ray itself uses .m2t files (eg, MPEG-2 transport stream) as its native video format. Nero Burning ROM can burn you a UDF or ISO disc, but that’s still not a proper Blu-ray video disc.
The PS3 shows the discs as “Data” under the Video menu. I’ve tried two PS3 consoles, including a brand new unit, and the problem occurs on both. What am I doing wrong? Many thanks!
Yes.. you have just made a data disc.
If you want to make a Blu-ray video disc, you need to make a Blu-ray video disc. I don’t know all the ins and outs of Vegas Studio Platinum. On full Vegas anyway, you can render either a BDAV disc or a BDMV disc. BDAV is a single video, and you can render that directly from the Vegas time line. BDMV means “movie”, and that’s the fully authored Blu-ray, with menus and all that stuff. In the usual workflow, you create this in DVD Architect. I would assume its somewhat similar in Studio Platinum. Also, there’s no need to run Nero; Vegas is absolutely capable of burning the BDs once complete.
I have made dozens of fully authored Blu-ray discs, and I use a PS3 as my only BD player (well, other than my PC). My discs, created in DVD Architect, play just dandy on the PS3.
-Dave
