Activity Forums Adobe Premiere Pro Problem converting to DVD…
  • Problem converting to DVD…
    Posted by Mans_manjunath on August 24, 2006 at 1:44 pm
    I took a video in cinemascope format(16×9)… but when i burn the video into DVD, and played it in TV… it runs in the full screen format…
    Pls give me the appropriate details to rectify this problem…
    Cal Johnson replied 20 years ago 2 Members · 1 Reply
  • Cal Johnson
    September 4, 2006 at 12:27 am
    It’s hard to give you specific details as your post is fairly generalized and the problem could be occuring at a number of different stages between capture and final DVD output. Basically, you must make sure that the 16×9 format is being honored through each stage of the process. Your Premiere project should be DV Widescreen, 16×9 1.2 pixel aspect ratio. If you’re using Premiere 2.0 you can export right from the timeline to DVD (this may be true of other versions of Premiere Pro, but I went from version 6 to Pro 2.0, so I’m afraid I can’t tell you what the versions in between are capable of).
    Exporting from the timeline is a great option, as the default settings for the DVD should nicely match your project settings. Still, be sure that the DVD is being formatted as 16×9. If you can’t export your timeline directly to DVD, you’ll have to make an AVI file, and then bring it into a DVD authoring software package, and create the DVD from there.
    To break it down, there are three areas where you might be likely going wrong:
    1) capturing the DV footage with capture settings that are not 16×9.
    2) not having your project settings set to 16×9. (which will also cause problem #1)
    3) Authoring the footage to DVD with incorrect transcode settings (probably the most likely culprit).
