Activity › Forums › Apple Final Cut Pro Legacy › Problem Codec
  • Posted by Andrew Cross on February 5, 2014 at 2:04 pm
    Hi Guys,
    Thanks in advance for all of your help.
    I’ve received files that I cannot get to read in Log and Transfer or any other software.
    The folder structure is
    Foldernumber> and then 5 files, MP4, SMI, PPN, XML, BIM.
    I’m sorry if I’m being dense but I’ve google around alot and found no workflow to help. Log and Transfer does not recognise the folder structure.
    Many Thanks
    Andrew
    Shane Ross replied 12 years, 7 months ago 2 Members · 1 Reply
  • Shane Ross
    February 5, 2014 at 5:14 pm
    That’s because it’s XDCAM. You need to use the XDCAM TRANSFER UTILITY for that.
    Shane
    Little Frog Post
