Activity Forums Apple Final Cut Pro Legacy Problem capturing with Tiger
  • Problem capturing with Tiger
    Posted by Olivier Jean on June 11, 2005 at 8:04 am
    Hi All !
    well, i’m doing my first Tiger/FCP Studio/PMG5 2.7MHz- 2.5GB RAm/Atto/SCSI Raid ( this is not huge raid but i tried with a pretty full huge raid system and i got ze beach ball ! 🙁 )
    ( did heaps under Panther ) with great success.
    All is well after doing 10.4.1 then Quicktime 70.1, Latest Atto,
    FCP Studio then BM drivers. I mean i can play back raid speed is where it should be.
    But i did a capture today 10 Bit or 8 Bit and i noticed that the video in the capture window
    would do so kind of freeze frame then the video would look ok, then steppy then frezze frame
    and eventually i would get a dropped frame message. Tried many times same results.
    I did the usual stuff ( trashing pref, reinstalling Atto drivers…. ) no joy.
    So i tried to capture to the internal Sata, no problem at all.
    So i thought it could be the Raid although the reat shows 220MB and the write is 160MB !
    I hook up a back up system with 10.3.8 and it worked great… look like a Tiger Problem.
    HAs anyone seen this issue?
    any help would be appreciated.
    (BTW i swapped the Atto card as well)
    maybe some one has a old version which should do the trick.
    Regards
    Olivier Jean
    Powermedia Systems
    Sydney Australia
    Olivier Jean replied 21 years, 2 months ago 1 Member · 0 Replies
  • 0 Replies
