Activity Forums Apple Final Cut Pro Legacy problem capturing HDV
  • problem capturing HDV
    Posted by Austin Reedy on November 2, 2010 at 10:30 pm
    hi all
    i am capturing HDV material shot on the Sony V1U. I’m not sure what is happening…the footage is coming in as 720×480. I have the easy set up to capture HDV for editing in 1080p30 Firewire Basic. This is the first of the stuff i’ve captured, everything else i’ve been given was captured previously and is 1440×1080. I’ve run footage through the JES Deinterlacer as its 24p as well.
    I’m sure i’m missing something really simple with the capture, i just am not sure what other direction to give FCP to capture. oh and also i’m using a sony HDV deck to capture.
    please help if you can. thanks
    Austin Reedy
    Freelance Post
    Austin, TX
    Michael Gissing replied 15 years, 10 months ago 3 Members · 7 Replies
  • 7 Replies
  • Michael Gissing
    November 2, 2010 at 10:59 pm
    Check that the deck is not down converting to DV. Also make sure your easy setup is correct.
  • Austin Reedy
    November 3, 2010 at 12:17 am
    the easy set up is this:
    format: HDV
    Rate: 29.97
    Use: HDV – 1080p30 FireWire Basic
    does that seem right? i looked at the other fire wire options and they’re obviously incorrect. somehow its capturing it as widescreen DV…853×480.
    if it is downconverting somehow i’m not sure how to fix that…not my deck and it is confusing to operate as is.
    Thanks for your help
    austin
    Austin Reedy
    Freelance Post
    Austin, TX
  • Michael Gissing
    November 3, 2010 at 1:05 am
    Easy Setup looks right. Check the menus in the deck and look for downconvert via firewire. Manuals for most decks can be found online in minutes.
  • Michael Gissing
    November 3, 2010 at 1:06 am
    And the other issue is to check if the tapes are HDV or DV. The Sony V1 can shoot both. If you play a tape, the deck should indicate if the tape is HDV or DV
  • Paul Jay
    November 3, 2010 at 6:32 pm
    You probably have iLink conversion ON in the camera/deck. It should be set OFF.
    Check your camera/deck settings.
  • Austin Reedy
    November 4, 2010 at 4:24 am
    i.link conversion was on. problem solved. thanks a lot! what exactly is the i.link conversion option for?
    Austin
    Austin Reedy
    Freelance Post
    Austin, TX
  • Michael Gissing
    November 4, 2010 at 4:37 am
    ilink conversion is the option to downconvert from HDV to DV codec (standard def) via firewire.
