Activity Forums Apple Final Cut Pro Legacy Problem capturing DV 24F(progressive) footage
  • Problem capturing DV 24F(progressive) footage
    Posted by Catherine Ceigersmidt on January 26, 2009 at 10:17 pm
    I am attempting to capture some footage using a Canon HV10 camcorder via firewire, but the footage appears to have been shot in standard DV 24F, according to the playback display on my camera. I’m using Final Cut Pro 6.0.5. The clips captured have lots of vertical pixel lines, particularly in areas of the picture that are brightly lit. It doesn’t seem to matter what my DV NTSC capture settings are, nor the DV firewire device control preset option — I get the same lines every time I simply playback or capture via firewire. When I connect my Canon to an NTSC monitor and playback the tape, the footage looks fine, no lines. I have no idea what type of cameras were used on the shoot, so could it be that they were shot in the usual 24p, but not Canon’s unique proprietary format of 24F?
    Cathy
    Chris Borjis replied 17 years, 7 months ago 2 Members · 1 Reply
  • Chris Borjis
    January 26, 2009 at 11:02 pm
    load up some of that footage you captured.
    play it with FCP THROUGH the canon camera TO the TV.
    does it look fine?
    if so your A-OK.
