Activity Forums DaVinci Resolve Problem calibrating a LCD
  • Problem calibrating a LCD
    Posted by Francois Xavier on September 11, 2014 at 5:06 pm
    CalMAN 4.5.6 / Windows 7
    Calibrating an LCD using burned AVSHD Blu-Ray
    the source setings in “Optical Player … (manual control) but I appear to be stuck with the Generic calibration DVD workflow !. Can’t change it on the left tab
    At the gamma step I don’t have the bar with the numbers at the bottom of the interface, under the curve.
    That bar from 0 to 100 is missing
    I can’t “indicate ” to Calman the value pattern the metter is analyzing. It doesn’t present itself as I see it on the step bye step pdf
    why ?
    thank you to help me
    Juan Salvo replied 11 years, 11 months ago 2 Members · 1 Reply
